555 4017 led simulation using yenka program
Discussion in 'The Projects Forum' started by customsportbike, Feb 14, 2010.
  1. customsportbike
    Feb 3, 2010
    Hi guys, just found this great program which can simulate electronic diagrams. It called Yenka and it was free for a 15 day trail.
    The question I've got is how much voltage can the 4017 decade counter handle. I have simulated a bunch of 555 and 4017 led flasher circuits but the simulator all ways tells me the 4017 pin voltage has been exceeded and can only handle 1v.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Not familiar with that simulator, however, other simulators require a VDD=xxV parameter to model the supply voltage dependence of the 4000 series of CMOS logic.
  4. Alberto Leandro Tupone
    Jun 21, 2015
    18
    It happens to me, I can't do anything with this. Did you solve it?
  5. MrCarlos
    Jan 2, 2010
    400
    134
    Hola Alberto Leandro Tupone
    You've bought the software ???
    No.. .
    Probably the temporary license period is over.
    We could see us your design with the intention of seeking some mistakes ??
    you could compress your file ***. YKA with WinZip or WinRAR and upload the compressed file.
  6. crutschow
    Mar 14, 2008
    13,524
    3,392
    I suggest you try the LTspice simulator.
    It's free from Linear Technology and many on these forums us it.
  7. Alberto Leandro Tupone
    Jun 21, 2015
    18
    Thanks a lot crutschow. Actually this is pretty weird, it doesn't take any voltage for above of 6v. I'll try the LTspice.
    By the way, with this soft can also make a PCB? Thanks a lot! :)
  8. crutschow
    Mar 14, 2008
    13,524
    3,392
    No, LTspice is just a simulator.
