50W Car Amp
Discussion in 'General Electronics Chat' started by Overclocked2300, Sep 8, 2005.
  1. Overclocked2300
    Thread Starter Senior Member
    Apr 24, 2005
    124
    Alright well I have this 50W amp from a friend. 2 Channels use for cars (by the way it looks). I have sufficant power (12V using a ATX 300W PSU), but if I turn up the volume on the input up to much it cuts out, but the amp has been running for a while. It does the same thing if I turn up the balance too much to one channel (but Im only using 1 Channel)
    The amp heats up pretty good no matter what the load. I assume to make it stop from cutting out is to cool it a bit. It just uses passive cooling.
    It also isnt stable at time (I get static, poping..etc) I assume this is because of thermal run away. When the amp is cool or starting up its fine.
    So is the answer to cool it off with a fan?
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    i can't definitely say a cooling fan is the answer, but give it a try first, if it does not cut out,, then heat was just the problem. if it still cuts out something else is wrong.
    moz
  3. NickC84
    Sep 13, 2005
    9
    The AMP cuts out or the Sound cuts out? If the AMP cuts out it's thermal protection kicking in and yeah its getting too hot. If the sound cuts out then its clipping. Either way a 50W amp shoulden't get really hot, I think your pushing it way to hard either way. Back off it a bit if you want the amp to last.
  4. Overclocked2300
    Apr 24, 2005
    124
    The fan worked. It runs fine now. I didnt have a good ground, but I think the thermal protection came into play too.
