50Hz notch filter
Discussion in 'The Projects Forum' started by Asdis, Nov 30, 2010.
  1. Asdis
    Nov 30, 2010
    6
    Hi
    I need to design a notch filter that filters out 50Hz noise. I don't know how to start. Any ideas??
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. tyblu
    Member
    Nov 29, 2010
    199
    16
    Start with your requirements such as power (voltage, current), Q-factor, maximum attenuation, cost, and manufacturability (one-off or mass-production?).
  5. tom66
    May 9, 2009
    2,613
    214
    Paste this code into Falstad circuit sim: http://www.falstad.com/circuit/
    Code ( (Unknown Language)):
    1.
    2. $ 1 5.0E-6 5 50 5.0 40
    3. % 0 28853.998118144256
    4. l 352 32 352 128 0 0.0159154943 0.0
    5. c 352 128 352 224 0 6.366197723699999E-4 0.0
    6. r 240 32 352 32 0 100.0
    7. O 352 32 416 32 0
    8. g 352 224 352 256 0
    9. 170 240 32 208 32 3 20.0 60.0 5.0 0.5
    10. o 5 64 0 34 5.0 9.765625E-5 0 -1 in
    11. o 3 64 0 34 5.0 9.765625E-5 1 -1 out
    12. o 0 64 0 34 10.0 0.025 2 -1 inductor
    13. o 1 64 0 34 10.0 0.025 2 -1 cap
    14.
    It's approximately 50.1Hz, but it wouldn't be manufacturerable with standard values.
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The power mains is very noisy. If you filter out the 50Hz fundamental frequency then you still have plenty of 100Hz and 150Hz harmonics plus dimmer buzz and other interference.
    In some countries (I am not allowed to say where) the mains frequency varies all over the place so a high-Q notch filter won't work.
  7. kubeek
    Sep 20, 2005
    4,688
    806
    Why is that?
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    "I am not allowed to say where"
    A moderator here does not like when I comment about the extremely poor quality of products (and people) of 3rd-world countries.
  9. JoeJester
    Apr 26, 2005
    3,401
    1,218
    You don't need to be in a third world country to have harmonic rich power.
    I do know that JA Pierce, who selected 10.2 kHz as the Omega Navigation System's frequency say he wished he didn't choose that frequency as it is the 170th Harmonic of 60 Hz. Obviously there were some interference problems.
    Also PLC's, Power Line Carrier, has been known to interfer with systems in the 100 kHz band ... Loran-C ... but now that the government shut down all the Loran-C stations, that is no longer an issue. The one I observed caused a minor 1788 miles error in the distance between me and home. I was less than 10 miles from home at the time.
    Here's the spectral view I did in Feb 1999.
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    Its odd-order harmonics are pretty high so the sine-wave is "compressed" on its peaks.
  11. Asdis
    Nov 30, 2010
    6
    I have an EMG signal, I have made a Butterworth filter to filter out some other unwanted frequencies but now I just want to get rid off the 50Hz :)
    Thanks for all of your advice :)
  12. Audioguru
    Dec 20, 2007
    9,411
    896
    An ECG circuit usually uses an instrumentation amplifier that has very good common-mode rejection and "right leg" cancellation of common-mode AC and DC signals.
  13. JDT
    Feb 12, 2009
    658
    85
    One way to do this is to use a Twin-Tee Notch filter like this:-
    http://cnyack.homestead.com/files/afiltimp/notch1.htm
    Not too difficult to build. Google for other information.
    To get a very sharp notch, the component values need to be accurate. The frequency and sharpness of the notch will drift with temperature. As someone pointed out, the mains frequency may vary and you will not be filtering out the harmonics.
    A better solution is to use a comb filter:-
    http://en.wikipedia.org/wiki/Comb_filter
    As these are usually built using switched capacitor or digital techniques the filter can be made very accurate and can track the mains frequency. This is quite advanced stuff- not easy for a beginner!
  14. Asdis
    Nov 30, 2010
    6
    Where do I find the formula to calculate the order of a Notch filter? :confused:
  15. Asdis
    Nov 30, 2010
    6
    how do I find the filters orden?
  16. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    On Notch filters you do not use the therm order.
    A Q-factor is used on Notch filters for the quality of the filter.
    Take a look at section 5 of the attached PDF for more info.
    The other PDF is to look at the quality of the filter versus component tolletance.
    Bertus
  17. tyblu
    Member
    Nov 29, 2010
    199
    16
    There are many types of notch filters.
  18. Asdis
    Nov 30, 2010
    6
    Ok, if I use a Twin-T filter. Do you know how I find the order for that? or maybe where I can find some examples?
    I´m new to this circuit building stuff and so not getting this.... hope I will see the light soon :p
  19. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  20. tyblu
    Member
    Nov 29, 2010
    199
    16
    I hadn't heard that term before. Plugging it into Google yields dozens of examples. I didn't see a multi-stage version in the 2 I clicked, but it is basically a combination of two 1st order filters -- a high pass and a low pass. This means you will be -20dB/dec per 'order'. Given a minimum attenuation at a certain frequency and a symmetric circuit, you have a solution.
