did not want not really get into building it myself--time shortage here. The one (t2) I have been using is from a fencer company. Guess better check another place. At least that will give me something to check against. If they are the same, then look elsewhere.Which new parts did you fit when your trouble started?
Wherever you source T2 from, make sure that the LV and HV windings are totally separated from each other. Secondly, all windings should be layer-wound with proper insulation between layers. Thirdly, the coil sides are potential break-over points, either between different layers or between a layer and the core material, therefore enough gap should be allowed during the construction of the transformer. Last, but not least, it should be heated in a furnace, then dipped in insulating varnish, removed after impregnation and baked until dry and hard.
The current is not directly responsible for the damage done to T2, but rather the associated high voltage spikes that cause a breakdown in insulation, effectively shorting out HV turns, rendering them useless thereafter. This is why I emphasize the importance of a carefully designed and constructed transformer. (Do-it-yourself if you have the time).
Some fence charger manufacturers sell spares for their products and perhaps you should try to get hold of transformers this way.
Good luck!
here is the schematic from the fist post.
have a nice day :>)
Bladerunner
