Marked up drawings huh... LOL...Had only MS Paint that let me draw on an existing picture (png, jpeg,e tc) As far as the conventional flow not electron flow, Welcome to my world where conventional flow rules. I may even wire up a house to be smart but as far as the nuts and bolts (circuits), well.....Looking at your marked up drawings showing current flow. Your arrows show conventional flow, not electron flow.
The left hand drawing seems to be correct. However, the right hand drawing shows the current going to the left through D4. During that half cycle, D4 will be reverse biased so the current will go straight down at the right side of D4 and return to the top of the secondary winding of T1.
while your post was for yesterday at 3:59PM. I did not get your post until this evening. I posted two other drawings (even worse than before, lol). that represents the pos and neg waves. are these right.
Will do that with hast.As for voltage doubling, there are two ways. 1) use the transformer wired as an autoformer. All that means is that a winding is placed in series with the winding to which power is applied and phased in such a way that the voltages add. Many transformers have dual primary windings so they can be used on either 120 or 240 volt circuits. For 120, normally, the primaries are connected in parallel. For 240 volt operation, they connect in series with the center connection insulated. Sort of like putting two penlight batteries in parallel or series. This works for AC.
2)To double the DC voltage use capacitors and rectifiers. The theory is that on one half cycle, all the voltage is used to charge the capacitors through a diode. On the other half cycle, the first diode will be reverse biased and not conduct, BUT a second diode will effectively take the charge on the capacitor and ADD it to the source voltage. There are a couple of different configurations on how this is done, but your circuit is one of them. A Google search of "voltage Doubler" should give more detailed information.
Thanks again
Bladerunner
