I need to solder a 50 mil / 23 ways (1.27 mm / 23 ways) socket on my PCB.
I've started to design this new device with Eagle, creating a new library.
Socket spec:
- The socket is a 50 mil inch / 23 ways. (1.27 mm / 23 ways)
- Drill/Hole size is 31 mil inch. (0.79 mm). As per constructor datasheet.
Ive an issue with pad size/ restring.
Clearance between pads should be 8 mil (default Eagle setup).
Socket Pin Spacing : 50 mil
Clearance : 8 mil
Drill Diameter : 31
Free space for the Restring : (50-8-31)/2 = 5.5 mil.
5.5 mil is out of most of PCB rules and limits.
Any clue on how can I design the footprint for this socket ?
Regards,
Hyp.
Socket spec:
Clearance : 8 mil
Drill Diameter : 31
Regards,
Hyp.
