I need help creating an LED circuit. I'm trying to make an infrared flood light using 50 IR LEDs. The 'light' is to be powered by a single 9 volt battery and last approximately 6 hours before draining a battery. The LEDs in question use a forward voltage of 1.3 volts, have a 1.2 volt drop and draw 50 mA each. The data sheet can be seen here LINK.
There is currently a light in production that uses these same specs, so I know it can be done, I just can't figure out the proper configuration and resistors to use. Any help would be GREATLY appreciated.
Thanks!
Thanks!
