50 Hz waveform
Discussion in 'Homework Help' started by liam, Apr 27, 2008.
  1. liam
    Apr 22, 2008
    9
    could any one help us with this i have no idea where to start Find the instantaneous value of a 50 Hz waveform with a maximum value of 200v. 0.001 sec after it has passed through a voltage zero. many thanks . liam
  2. mik3
    Feb 4, 2008
    4,846
    63
    v=Asin(2πft)
    where v is the instantaneous voltage
    A is the peak (maximum) voltage
    f is the frequency
    t is the time
    so v=200sin(2πx50x0.001) =1.097 Volts
    You said when it has passed through zero: so it may be positive like + 1.098 or negative like - 1.097
  3. silvrstring
    Mar 27, 2008
    159
    Shouldn't this be done using radians? v(.001) would then be (+/-)61.8V.
  4. mik3
    Feb 4, 2008
    4,846
    63
    No, he said 0.001 seconds not radians
  5. silvrstring
    Mar 27, 2008
    159
    Yes, I know .001 is time, but omega(2pif) is in radians.
  6. mik3
    Feb 4, 2008
    4,846
    63
    no its in radians per second and time is in seconds so id you multiply them you get radians
  7. silvrstring
    Mar 27, 2008
    159
    Right. So you get 200sin(pi/10), or 200sin(18degrees). Both are 61.8V, right? Am I doing something wrong?
  8. Caveman
    Apr 15, 2008
    471
    The dimensional analysis is:
    t in seconds.
    2*PI = radians/cycle
    f = cycles/sec.
    2*PI*f*t = radians/cycle * cycles/sec * sec = radians.
    So, take the sine in radians. The 61.8 magnitude is correct.
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    I got 61.8 as well.
    hgmjr
  10. silvrstring
    Mar 27, 2008
    159
    Ok. Thanks.
  11. mik3
    Feb 4, 2008
    4,846
    63
    Oh yes you are right i forgot to make radians in degrees thanks for the correction. Stupid i am !!:)
  12. liam
    Apr 22, 2008
    9
    Thanks for the replies guys. but im still none the wiser as were you got the answer from . i understand that the answer is 61.8v. but where did this come from . when i tried working out the equation v=200sin(2πx50x0.001) =1.097 Volts i got - 0.107 ????
  13. Caveman
    Apr 15, 2008
    471
    Okay, step by step
    1. 2*PI radians/cycle * 50 cycles/second * 0.001 seconds = 0.314 radians
    This is just stating that 0.001 seconds into a 50Hz sine wave is 0.314 radians in.
    2. Take the sine of this, but remember to set up your calculator to calculate your trigonometric functions in radians. So, sin(0.314 radians) = 0.309
    Just so you understand, what this says is that at 0.001 seconds into a 50Hz sine wave, the voltage is 0.309 times the peak.
    3. Multiply by the peak voltage, 200V. 200V*0.309 = 61.8V.
    Got it?
  14. liam
    Apr 22, 2008
    9
    your a absolute star! thanks for the really easy explanation. ive managed to work it out
