50 HZ equipment
Discussion in 'General Electronics Chat' started by allied, Mar 27, 2007.
  1. allied
    Thread Starter Active Member
    Mar 11, 2007
    37
    Hi...
    My sister buy a nebulizer at the italy and she brought it in our country (asia) my problem is the unit spec. is 50HZ only. In our country the power lines used 60HZ the unit cannot able to provide enough air pressure I mean the air produce is low. Is there any solution with this?
    Allied
  2. kender
    Jan 17, 2007
    263
    The only practical solution I can think of is a 50Hz inverter.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    You may also have voltage issues. If the voltage is the same then you'll need a device that converts your voltage and frequency to the voltage and frequency the machine requires.
  4. allied
    Mar 11, 2007
    37
    I searched the frequency converter on the internet..It seems that the frequency converter is much expensive compare to our nebulizer...I will try to canvass in our place if i can find a cheap one...hehehe
    THANKS....
    Allied
