50/60Hz Powerline Noise
Discussion in 'General Electronics Chat' started by shravanraghu, Oct 22, 2014.
  1. shravanraghu
    Oct 22, 2014
    Hello
    I am designing an external battery pack to power an ECG amplifier. The ECG amplifier does not have a notch filter and the adapter used to power it does not have a 'GND' pin. The same adapter is being used to recharge the external battery pack as well. So i still have the powerline noise and i have a possibility of removing the powerline (50/60Hz) noise in the external battery pack i am designing.
    The input for the external battery pack is 12V--4A so using a RC lowpass/notch filter to remove the noise would dissipate a lot of heat. I wanted to know if there is any special kind of ic/circuit to remove this powerline (50/60Hz) noise from the power supply. The 50/60Hz interference problem occurs from the AC mains whilst charging the battery pack and using the ECG simultaneously.
    Thank You
    Shravan Raghu
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You could use common mode chokes on either the AC pair, or the DC output. Next would be a pi filter of one or more sections.
    An IC -- sorry I don't think that is going to happen for powerline applications.
  3. shravanraghu
    Oct 22, 2014
    Thanks for the reply. I was looking for a method to eliminate noise on the powerline DC output I get from my adapter because I cant modify my adapter. Do you know any method of eliminating noise on the powerline?
  4. ronv
    Nov 12, 2008
    3,400
    1,457
    Filter the voltage going from the battery to the circuits instead.
  5. shravanraghu
    Oct 22, 2014
    The batteries voltage does not have the 50Hz noise. So I have no issues there. The issue is only when I charge my external battery pack and this external battery pack is connected to ECG simultaneously. As ECG is a biosignal it contains information at 50Hz which gets contaminated with powerline noise.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    But the noise has to get from the charger to the circuits. Put the filter on your device and the battery won't even know, or care, that it is there.
