Hello
I need some help with a working design. I would like to build a 5 LED ( SMD 0603 in that size/shape range) circuit. The circuit should turn on LED1 then off then LED2 on then off till LED5 same thing then start at LED1 again in order.
I would like to use a 555 I.C with a 5 - 6v range, main battery. I would like to be able to adjust the flash rate to speed up or slow down the flash rate.
I want the circuit to be as small as possible on a circuit board because of size restrictions; 1"x1" or 1"x2" in that range.
For my First attempt, I would like to use 5 average LEDs on my experimentors board to see if it works and get assembly practice.
Hope someone can help me with this circuit.
George
George
