****PLEASE HELP****** hey guys,i'm supposed to make a 5 bit code converter(counter) from gray code to binary code that counts from 0 to 31 (from 00000 to 11111).I've started by selecting the minterms which the gray code would be high and connected them to nand gates. Example , the MSB would be ''high'' only when one of the minterms from 16 to 31 is ''HIGH''. please explain which IC should i use , is it a decoder or 4-16 demux. thanks guys
