Thanks.Hello,
I made a little change in the schematic.
With the modification, the voltage can be adjusted between ca. 5.00 and 5.26 Volts.
Bertus
With the help of everyone who posted (and reading the datasheet a little more closely,) I think I am getting there. However, I have decided to use an ADC reference of 4.096V derived from the 5V supply. I have modified your modification to achieve that.
It seems to work properly, but I still have one question regarding R3 in my schematic. The datasheet says that R3 should be sized to provide cathode current of at least 1mA at the lowest expected Vin. I tried your value of 2.7k and the TL431 would not regulate, so I scaled R3 down in the approximate ratio of 12 to 5, and arrived at 1k, which seems okay.
My question is how does one actually calculate the cathode current in this circuit? Thanks again to everyone, and please excuse my ignorance.
