4x4 Keypad Issues
Discussion in 'The Projects Forum' started by steveG567, Nov 4, 2008.
  1. steveG567
    Nov 4, 2008
    I have written a program in C on a freescale 8 bit micro.
    The code is:
    Code ( (Unknown Language)):
    1.
    2.   while (column==1)
    3.   {
    4.
    5.    PTBD = 0xFE;
    6.
    7.     if (PTBD == 0xEE)
    8.      {
    9.       PTDD = 0x01;
    10.       lcd_delay(2000000);
    11.       PTDD = 0x00;
    12.      }
    13.
    14.      if (PTBD == 0xDE)
    15.      {
    16.       PTDD = 0x02;
    17.       lcd_delay(2000000);
    18.       PTDD = 0x00;
    19.      }
    20.
    21.
    22.      if (PTBD == 0xBE)
    23.      {
    24.       PTDD = 0x03;
    25.       lcd_delay(2000000);
    26.       PTDD = 0x00;
    27.      }
    28.
    29.      if (PTBD == (0x7E))
    30.      {
    31.       PTDD = 0x04;
    32.       lcd_delay(2000000);
    33.       PTDD = 0x00;
    34.      }
    35.      else column = 2;
    36.   }
    37.
    38.
    39.   while (column==2)
    40.   {
    41.
    42.     PTBD = 0xFD;
    43.
    44.
    45.     if (PTBD == 0xED)
    46.      {
    47.       PTDD = 0x05;
    48.       lcd_delay(2000000);
    49.       PTDD = 0x00;
    50.      }
    51.
    52.      if (PTBD == 0xDD)
    53.      {
    54.       PTDD = 0x06;
    55.       lcd_delay(2000000);
    56.       PTDD = 0x00;
    57.      }
    58.
    59.
    60.      if (PTBD == 0xBD)
    61.      {
    62.       PTDD = 0x07;
    63.       lcd_delay(2000000);
    64.       PTDD = 0x00;
    65.      }
    66.
    67.      if (PTBD == (0x7D))
    68.      {
    69.       PTDD = 0x08;
    70.       lcd_delay(2000000);
    71.       PTDD = 0x00;
    72.      }
    73.      else column = 3;
    74.   }
    75.
    76.
    77.
    78.
    79.   while (column==3)
    80.   {
    81.
    82.     PTBD = 0xFB;
    83.
    84.
    85.     if (PTBD == 0xEB)
    86.      {
    87.       PTDD = 0x09;
    88.       lcd_delay(2000000);
    89.       PTDD = 0x00;
    90.      }
    91.
    92.      if (PTBD == 0xDB)
    93.      {
    94.       PTDD = 0x0A;
    95.       lcd_delay(2000000);
    96.       PTDD = 0x00;
    97.      }
    98.
    99.
    100.      if (PTBD == 0xBB)
    101.      {
    102.       PTDD = 0x0B;
    103.       lcd_delay(2000000);
    104.       PTDD = 0x00;
    105.      }
    106.
    107.      if (PTBD == (0x7B))
    108.      {
    109.
    110.       PTDD = 0x0C;
    111.         lcd_delay(2000000);
    112.       PTDD = 0x00;
    113.      }
    114.      else column = 4;
    115.   }
    116.
    117.
    118.   while (column==4)
    119.   {
    120.
    121.    PTBD = 0xF7;
    122.
    123.
    124.     if (PTBD == 0xE7)
    125.      {
    126.       PTDD = 0x0D;
    127.       lcd_delay(2000000);
    128.       PTDD = 0x00;
    129.      }
    130.
    131.      if (PTBD == 0xD7)
    132.      {
    133.       PTDD = 0x0E;
    134.       lcd_delay(2000000);
    135.       PTDD = 0x00;
    136.      }
    137.
    138.
    139.      if (PTBD == 0xB7)
    140.      {
    141.       PTDD = 0x0F;
    142.       lcd_delay(2000000);
    143.       PTDD = 0x00;
    144.      }
    145.
    146.      if (PTBD == (0x77))
    147.      {
    148.       PTDD = 0x10;
    149.       lcd_delay(2000000);
    150.       PTDD = 0x00;
    151.      }
    152.      else column = 1;
    153.    }
    154.
    Pins 4,5,6,7 are inputs pulled high
    the rows are outputs pins 0,1,2,3 and polled.
    Now, the 4th column works perfect. The first three dont. When I put an o-scope up to the pull up resistors, I get a voltage drop of around 0.5V, so the votlage is dropping, but not from 5-0V. I have NO IDEA why this is happening. ALl the code seems the same to me, why does column 4 work and not 1,2 or 3??
    Any help would be great.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A schematic would be most helpful.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    In addition to a schematic, you will need to post the rest of your source code.
    The value of the variable "column" may be getting unintentionally altered somewhere else in your code.
    hgmjr
