4SignalTransistor
Discussion in 'General Electronics Chat' started by mpuvdd, Sep 30, 2007.
  1. mpuvdd
    Thread Starter Active Member
    Feb 11, 2007
    50
    Hello all,
    Say I have 4 signals all in parallel. Rather than using transistors to control each individual line, what kind of IC or setup could I buy/make so that I can simply turn on, or off, all four signals at once. Like a transistor w/ four individual bases and emitters. Thanks a lot.
    mpuvdd
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Are the 4 signals you need to turn off and on, digital signals or analog signals?
    If analog, what is the voltage range associated with the signals?
    hgmjr
  3. mpuvdd
    Feb 11, 2007
    50
    It's digital:cool:
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    An SPST Analog switch such as a 4066 should do the trick.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    For 4 digital signals, the old 74LS125 or 126 is just the thing. Use the three state enables to turn the outputs on or off.
  6. mpuvdd
    Feb 11, 2007
    50
    Perfect! That was exacly what I was looking for.
    Thanks so much:)
    mpuvdd
