4nec2 and circular antenna
sdow
Joined Aug 25, 2016
Hello
I am working on circular antennas RHCP and LHCP . I use the 4nec2 to simulate my antennas but i think that 4nec2 can calculate correctly the axial ratio of antennas . Can confirm that and what is the alternative to calculate the circular axial ratio of antennas with 4nec2 . Thanks
KL7AJ
Joined Nov 4, 2008
2,229
Hello
Yes you can....and if you go to the 3D plot, you can plot out the axial ratio directly, as well as the sense.
KL7AJ
Joined Nov 4, 2008
2,229
Here's an output file from 4nec2. I've removed everything above this, which is all the excitation information. The far field pattern is where you want to begin. :)
sdow
Joined Aug 25, 2016
if i understand the best axial ratio for circular antenna is 1 ....in this picture the axial ratio is very low ...
