what is the difference between 4N25 and TLP521?? Can I simply use 4N25 instead of TLP521
Thread Starter Abdel_Rahman Joined Jul 19, 2016 42 Nov 11, 2016 #1 what is the difference between 4N25 and TLP521?? Can I simply use 4N25 instead of TLP521
MaxHeadRoom Joined Jul 18, 2013 28,696 Nov 11, 2016 #2 Most probably, but what is the exact nature of the application? One is 6 lead the other 4. Max.
crutschow Joined Mar 14, 2008 34,459 Nov 11, 2016 #3 Abdel_Rahman said: Can I simply use 4N25 instead of TLP521 Click to expand... If the 4N25 meets your circuit requirements, then yes.
bertus Joined Apr 5, 2008 22,278 Nov 11, 2016 #4 Hello, If you can use the TLP521 in stead of the 4N25 depends on the used circuit. On the 4N25 the base of the output transistor can be used. The breakdown voltage of the 4N25 is higher as that of the TLP521. Bertus Attachments 4n2X_4N3X_ever.pdf 391.3 KB Views: 2 TLP521.pdf 372.8 KB Views: 2
