4G antenna
Discussion in 'Wireless & RF Design' started by R!f@@, Sep 29, 2015.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,785
    771
    Any body has any idea how o make a 4G Antenna?
  2. DickCappels
    Aug 21, 2008
    2,746
    665
  3. R!f@@
    Apr 2, 2009
    8,785
    771
    It's 4G not 4GHz.
    Will that work for me ?
  4. nerdegutta
    Dec 15, 2009
    2,565
    805
    Do you mean 4G as in cellphone signals? Then you need an antenna to match the cellphone type in your area. 900MHz or 1800MHz. To find the proper antenna length you divide 300 by the frequency. Then you get a full wave antenna. Divide that by 4 and you get a quarterwave antenna.
    I think it is like that... What are you building?
    R!f@@ likes this.
  5. MikeML
    Oct 2, 2009
    5,450
    1,066
    If the antenna is to be mounted remote from the phone, you will need a coax feedline (short as possible, because coax losses are very high at those frequencies). The antenna will have to be in the form of a 1/2λ dipole (not just a 1/4λ monopole). You will also have to devise some means of coupling the coax to the cell phone, which likely does not have an antenna connector for external antennas.
    R!f@@ likes this.
  6. R!f@@
    Apr 2, 2009
    8,785
    771
    I will do some research and get back
  7. Dodgydave
    Jun 22, 2012
    5,130
    766
    R!f@@ likes this.
  8. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    4G can have many frequencies depending on the country you are in.
    On the wikipage on 4G you will find more info about the frequencies and the ranges used:
    https://en.wikipedia.org/wiki/4G
    Bertus
    Sinus23 and R!f@@ like this.
