4bit synchronous counter using D Flip Flops
Discussion in 'Homework Help' started by dankipiti, Feb 13, 2005.
  1. dankipiti
    Feb 13, 2005
    This is an assignment for my Uni. I have to implement a synchronous counter using D Flip Flops. It should look something like this. http://babbage.cs.qc.edu/courses/cs343/200...signment_02.php
    I have on paper done all the combination logic and determened the inputs for all the flip flops.
    A0 = ~A0
    A1 = (~A1 A0) + (A1 ~A0)
    A2 = (~A1 A2) + (A2 A1 ~A0) + (~S2 S1 S0)
    A3 = (A2 A3) + (A3 ~A1) + (A3 ~A0) + (~A3 A2 A1 A0)
    The inputs to A0 and A1 were given but I dont understand the logic behind the inputs to the "AND" and "OR" gates. How to know which wire to assign as their inputs.For example, the ~Q output of A1 goes into an "AND" gate which leads back to the input of A1, why? Thanks in advance for any help.
  2. dragan733
    Dec 12, 2004
    One constructs a table with inputs parameters Q0, Q1, Q2, Q3 and outputs parameters D0, D1, D2, D3. Then with minimization of this table with, carnaugh map, one gives:
    Then you have a mistake, at the first term of D3. You wrote Q2Q3. It needs to be: Q2'Q3
