Do you mean that with this configuration i cant use a common earth between input and output?1) It depends on what is inside the converter. If the output is isolated, you can just connect whatever wire you want as "common".
2) You could think in terms of an inverting supply. Do you really need both boost and buck to get 12 volts out of -48 volts?
Sorry the output is not isolated.Do you mean that with this configuration i cant use a common earth between input and output?
You did not show a, "configuration". You just drew a square and called it a buck/boost converter.Do you mean that with this configuration i cant use a common earth between input and output?
Note, This chip is a Down Converter not a booster, with common 0V ground.LM2576
Any suggestion chip (60v) to do that?There is a circuit trick for doing part of what you want with a buck converter, but it will not work with this chip. And even if it did, you cannot ground the output side.
ak
by Jake Hertz
by Duane Benson
by Duane Benson
