48v to 40v
Discussion in 'The Projects Forum' started by alecjcook, Mar 18, 2014.
  1. alecjcook
    Jan 2, 2014
    5
    Hi. I am designing a bench power supply. My transformer will kick out 48v (1ish amp) but the supply I'm spec-ing we only do 36. My regulator has a max input of 40v, so my question in, what is the best way to get my 48v down to 40 cleanly? Would a voltage divider be enough? Or is that just wasteful?
  2. k7elp60
    Nov 4, 2008
    478
    69
    If the regulator is a 3 terminal regulator(input,output,and ground)you could put a zener diode from the ground terminal to ground. In other words connect the anode of the zener to the common terminal(ground) and the anode to ground, and a resistor from the cathode of the zener to the input.
  3. ScottWang
    Aug 23, 2012
    4,929
    777
    What is the regulator?
    What is the V,I,R of load?
    How is the power supply, fixed 36V or a variable voltage power supply?
  4. Plasmahunt3r
    Feb 6, 2014
    28
    There is a simple solution. Use a Transistor and Zener to create an Emitter Follower Voltage Regulator. Your Transistor can handle several Amps (I use MJE13007). Just pick a Zener voltage (+ .6V) as a reference voltage to apply to Transistor base and your output voltage would be that (minus .6v).
    alecjcook likes this.
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,689
    1,297
    1. Max. output current?
    2. Fixed or adjustable output voltage?
    3. Regulation tolerance (+/-1%, 5%, etc.)
    ak
  6. alfacliff
    Dec 13, 2013
    2,449
    428
    that 48 volt transformer will be more like 67 volts dc after rectification and filtering. dies it have a center tap? if so, a two diode bridge will get it down to what you are looking for.
  7. crutschow
    Mar 14, 2008
    13,492
    3,372
    That won't affect the voltage drop from input to output which is the critical value.
  8. crutschow
    Mar 14, 2008
    13,492
    3,372
    I would also recommend a pre-regulator such as Plasmahunt3r suggested.
    A technique to reduce the losses somewhat is to use the minimum filter capacitance on the rectifier output so that the lower voltage of the pp ripple is only about 40V at full load. This reduces the dissipation in the pre-regulator and also reduces the peak current from the transformer which reduces I squared R winding losses.
