Yes, this is correct. Wondering where I get a valid neutral. Normal installations that I see have three phases and a ground. Or - am I missing that they all have a neutral? Or - is the neutral not being brought to me?Presumably your 480V AC is a 3-phase supply and you are considering using the voltage from one phase terminal to neutral?
Are you in N.A.?Yes, this is correct. Wondering where I get a valid neutral. Normal installations that I see have three phases and a ground. Or - am I missing that they all have a neutral? Or - is the neutral not being brought to me?
WYE is very common. Where I worked last we had 480 WYE and used 277 volts for all the plant lighting. Where I work now we have 208 WYE, if anything I have seen less DELTA connections.I am in North America. Is 480V Wye uncommon in North America - Michigan? I understand the difference between ground and common also - essentially that's why I'm asking the question. Thanks for your help on this.
