480 volt single phase
Discussion in 'General Electronics Chat' started by curly, Oct 1, 2013.
  1. curly
    Oct 1, 2013
    I am new here can someone tell if I can use 2 legs of 480 volt 3 phase to get 480 volt single phase
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    What is the end use? Why do you want to? 480V is pretty high to be playing with for someone that needs to ask the question.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
    It can effectively be used as a 1ph supply at 480v.
    Max.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    It can also effectively blow your face off. Get somebody that knows the danger!
  5. sheldons
    Oct 26, 2011
    616
    101
    A 3 phase supply is NOT to be experimented with in any way unless you know exactly what the dangers are and what you are doing-it is very unforgiving of any mistakes ....
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
    These are the types of posts that should only have one answer and be closed..
    "Hire a qualified electrician"
    shortbus, GopherT and #12 like this.
