471127This is what I've learned
Discussion in 'General Electronics Chat' started by RemediosMorthland, Mar 30, 2012.
  1. RemediosMorthland
    Mar 30, 2012
    471127This is what I've learned, led strip blue
    there are 2 controller that are identical to one another, led strip 12v
    other than polarity. The one I have uses the black as a common ground while each color is 12v, waterproof led strip light
    I need this reversed (or vice versa, i kinda lost over sight now). Is this possible?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Was this a statement to someone, or were you trying to get some help?
    Your post does not make clear what you are asking/saying.
    If you are asking for help, I suggest that you start a new thread with a subject something like: "Reversing waterproof LED controller help?" and then please try to explain more thoroughly what you wish to do. I'm suggesting starting a new thread because you can't change the subject of the 1st post.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
