4541 Power On Reset
Discussion in 'General Electronics Chat' started by Clarence Donath, Apr 29, 2011.
  1. Clarence Donath
    Apr 29, 2011
    5
    Hello helpful allaboutcircuits forum people,
    I have one of these kits, http://www.canakit.com/universal-1-hour-start-stop-timer-kit-ck158b-uk158b.html
    It works perfectly for my needs, except that it "starts" when power is applied. The IC is a HEF4541B.
    I observed that holding pin 6 (MR) low on power up keeps the timer from activating, but this cannot be held low all the time since triggering a start causes the power supply to short. I'm thinking what I need is a short delay in holding pin 6 low at power up. Is there a simple RC network that can do this?
    Thank you
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    It's difficult to offer advice without a schematic. You might get the wrong advice and end up with your timer damaged.
  3. Clarence Donath
    Apr 29, 2011
    5
    You're right, I know. I don't have a schematic as it is a kit. However, pin 6 is unconnected. Knowing that holding pin 6 (MR) low already does what I need, I just need to come up with something that'll do this at power up.
  4. k7elp60
    Nov 4, 2008
    478
    69
    Looking at the data sheet, pin 6 (MR) needs to go high to reset the timer. If you want to activate the MR(pin 6) on power up. Connect a 0.1uf capacitor between pin 6 and VDD, Connect a 100KΩ resistor between pin 6 and ground (VSS) The value of the capacitor and the resistor determine the timing. With the above conditions pin 5 should be connected to VSS
  5. Clarence Donath
    Apr 29, 2011
    5
    Thank you for your reply k7elp60.
    I didn't have any luck experimenting with that configuration.
    What I've found, by experimentation, is that holding pin 6 on VSS at power up cancels the start cycle. I then release the connection of pin 6 to VSS and start/stop operations function as normal. The normal configuration of pin 6 in this circuit is floating. It's not connected to anything.
    Is there a circuit I can use that will make a connection to GND for a second, more or less, at power up, then release it to an unconnected state while powered up?
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    It's not recommended practice leaving CMOS inputs floating - they should be tied to an input - albeit to GND or Vcc if unused. Are you positive that pin is actually floating?
  7. Clarence Donath
    Apr 29, 2011
    5
    You are absolutely correct t_n_k. Pin 6 is indeed tied to the BGR resistor straight up from pin 1, which in turn is connected to the kit's STOP header. I failed to realize there are traces under the IC socket that couldn't see with the chip installed.
