Hi all,
I am using the 4510 counter and 4511 driver to display the clock cycles done in one second. For this reason, the counter has to be reset every one second and the 4511 enable pin has to be set at the end of every one second to display the cycles done in this time.
not the problem is that since the same 555 timer is used, the counter is being reset before the display shows the value. Hence, the display is always showing as '0'. How can i solve this problem please?
Thanks in advance.
Thanks in advance.
