4060 timer calculation
Andra
Joined Dec 22, 2014
5
I am building a circuit with a 4060 counter that I'd like to have a 60 minute cycle. How do I calculate the resistor and capacitor values I need at pins 9, 10, and 11? I know the resistors at pin 10 and the capacitor at 9 determine the oscillation, but what does the resistor at 11 do, and what are the ideal ranges for each of these?
MikeML
5,444
Do you want an output that is 30sec high and then 30sec low, or do you want a narrow pulse every 60sec?
k7elp60
Joined Nov 4, 2008
562
According to Don Lancaster in his book,"CMOS COOKBOOK". The resistor on pin 11 should be greater than 10 times the reistor on pin 10. The value of the resistor and capacitor connected to pins 9 & 10 is calculated by t(time)=2.2RC. Since the greatest division of the 4060 is 16384, if you multiply 30 minutes by 60(seconds/min)=1800 seconds. The divide 1800/16384 we get .10986 seconds The oscillator time. Then .10986=2.2R1uF. R=.10986/(2.2x1uf). R=49.93k. The other resistor needs to be greater than 500k ohms. I would like to point out that the time may not be very accurate as the value of the capacitor and the applied voltage will affect the accuracy.
MikeML
5,444
If the period of the output is 3600 sec (1800 sec high, 1800 sec low), then the period of the oscillator would need to be 3600/16384 = 0.21973 sec.
Here is the RC oscillator right off the data sheet:
I calculate that if Rx=100K, Rs can be 470K, and Cx would be 1uF
Wendy
Joined Mar 24, 2008
23,429
I've designed quite a few 4040 and 4060 circuits. I usually use a 555 to drive a relay for power applications, but this is not always needed.
Describe what you are driving and the on/off time of the pulse. You also need to think about accuracy, you can do this with one 4060 and a RC clock setup (part of the 4060) or with a crystal oscillator, your choice. The RC method is around 5% accurate, not very good but adequate for a lot of applications and definitely fewer parts.
Andra
Joined Dec 22, 2014
5
I am using the 555 to turn on an LED, and I'm not too worried about accuracy. What is the difference between an RC and a crystal setup?
Wendy
Joined Mar 24, 2008
23,429
Complexity and accuracy. A crystal can be used in a digital clock (12:00AM), where a RC clock is very loose (+/- 10%, maybe worse, depends on the effort you spend), but needs a LOT less parts.
A 4060 with a watch crystal can make a very accurate 2Hz signal, which you would then drive a second 4060 circuit with.
A RC 4060 can use just one chip (plus the 555 timer).
k7elp60
Joined Nov 4, 2008
562
The difference in this case is the frequency. With the RC the oscillator is at about 4.5Hz. With a crystal about the lowest frequency available for a small cost is 32.768Khz. You don't need a 555 to turn on the LED or other device with the 4060. Depending upon the current required a transistor will work fine.
Wendy
Joined Mar 24, 2008
23,429
Side note, I am assuming a 32.767Khz crystal (a watch crystal). A 4060 has a max division of 1/2 that, 16384. If you divide a 60 minute cycle (hz = (60*60)) by the 16384 you would need a base frequency of 4.55hz. So you would probably need a second 4060 if you chose to go the crystal method.
Wendy
Joined Mar 24, 2008
23,429
The difference in this case is the frequency. With the RC the oscillator is at about 4.5Hz. With a crystal about the lowest frequency available for a small cost is 32.768Kz. You don't need a 555 to turn on the LED or other device with the 4060. Depending upon the current required a transistor will work fine.
A 555 has the advantage of setting a set on time independent of the 4060. I have several tested circuits drawn up in other posts is the OP is interested. It caught my interest, I satisfied my interest, I moved on. :)
The other chip sounds interesting, but I keep 4060's in my parts kit. And lots of 555's.
To the OP: Me and 555s are an in joke on this site. I dearly love that little chippie.
Brevor
Joined Apr 9, 2011
297
I did this with an LS7210. Very similar to a 4060 chip, but allows for programming both time constants
Hi #12, Interesting you used that IC, LSI/MSI is kind of an obscure company but they make a lot of unique IC's.
Funny story, 20 some years ago I was looking to use some of their IC's in a custom product I was designing. I checked with the company for a local distributor. Turns out there was one located less than 1 mile from where I worked. I called them to place an order and since they were so close, could I just stop by and pick them up? "sure just stop in " was the answer, the address turned out to be a small house in a residential neighborhood. The guy took me down to the basement where he had a shelf full of tubes of IC's. He filled my order while I watched, I paid and left. He said this was just a small part time job he did to supplement his regular job.
#12
Joined Nov 30, 2010
18,224
I bought that chip from Radio Shack, long before I knew about this site or online vendors. Somewhere in the 1990's IIRC.
The point is, it was convenient to get this chip at that time. That's probably the major reason I used it.
Brevor
Joined Apr 9, 2011
297
After reading your post I became curious so I looked the company up and they are still around. They still sell that LS7210 IC you used , and that guy I bought the samples from is still listed as a distributor at the same address.
