4040 ic
Discussion in 'General Electronics Chat' started by ricker24, Mar 29, 2011.
  1. ricker24
    Mar 5, 2011
    53
    Hello, I am going to make a 21 led counter with a reset button and was thinking about using a couple of 4040 IC's. I have found some info on it but am not sure if I can cascade the 2 to get my 21 outputs. If anyone could help or suggest an IC to use it would be greatly appreciated. I have googled 21 led counter and can't really find anything of any use. I made a counter with the 4017 but it only has 10 outputs so as far as I can tell I would have to use 3 of them and I really don't want to do that. Thanks.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    You can connect the Q11 of the first to the clk/ connection of the second 4040.
    The reset lines can be put together.
    Code ( (Unknown Language)):
    1.
    2. [B]4040[/B]
    3.
    4.  12-bit asynchronous binary counter with reset.
    5.     +---+--+---+
    6. Q11 |1  +--+ 16| VCC
    7.  Q5 |2       15| Q10
    8.  Q4 |3       14| Q9
    9.  Q6 |4       13| Q7
    10.  Q3 |5  4040 12| Q8
    11.  Q2 |6       11| RST
    12.  Q1 |7       10| /CLK
    13. GND |8        9| Q0
    14.     +----------+
    15.
    This way you will have 24 stages.
    Bertus
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    A 4040 is a classic ripple counter, which counts in binary.
    A 4017 is a decimal counter that has been decoded to 1 of 10 outputs on at any one time.
    Fair difference between the two.
    A binary 21 counter has 2^21 counts, or decimal 2,097,152 ( a rather long count). 24 bits have decimal 16,777,216 counts.
  4. ricker24
    Mar 5, 2011
    53
    What chip would you recommend that I use then? I want the led's to light up 1 at a time with every push of a button but want the previous one to go off each time so that only one is lit at a time up to a count of 21. Thanks...
  5. KMoffett
    Dec 19, 2007
    2,586
    234
  6. nigelwright7557
    May 10, 2008
    488
    71
    Look up Johnson ring counter.
    This has one bit on while the rest are off.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
