4040 12-bits Counters
Discussion in 'General Electronics Chat' started by Olakunle, Mar 13, 2011.
  1. Olakunle
    Mar 12, 2011
    Dear sir,
    I want to read a frequency counter values with visual basic.
    I need 1s i.e 1hz from a 4mhz crystal and I have 2 4040 12-bit counters.
    I can divide each counter by 4096. The problem is that I need to divide one
    4040 by 4000 and the other by 1000 to get 1s.How should I divide by 4000 and 1000
    using AND Gates etc with the Counters?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you got data sheets? CD4020, 4040, and 4060 can all give shorter than maximum counts.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    But they can't divide by any number that is not a power of 2. You can use a 4.096MHz crystal, or a 1.024MHz crystal, or 32768Hz crystal, or... any crystal whose frequency is a power of 2.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    1000 = 1024 - 24. 24 = 16 + 8.
    4000 = 4096 - 96. 96 = 64 + 32.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    I forgot about decoding and short-cycling the counter.:(
    You can divide by 4000 with a CD4020, an 8-input AND gate (CD4068), and a couple of inverters from a CD4049.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Ah, but can the OP see the way to decode with the least logic?
