4027 toggle
Discussion in 'General Electronics Chat' started by richbrune, Apr 4, 2008.
  1. richbrune
    Thread Starter Senior Member
    Oct 28, 2005
    106
    I'm trying to set up a toggle output with simply a cd4027BE, 12volt supply. I've got J and K tied to 12 volt, set and reset grounded, and the button between the clock and +12v. I'm having trouble and I think it's because I need some kind of resistors in the circuit.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You put your post on an expired thread. That's a good way to have it ignored.
    Is your button debounced?
  3. richbrune
    Oct 28, 2005
    106
    Nope. is a 555 the easiest way?
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Here are some various debounce schemes, it doesn't need to be that complex.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Don't forget that the 4027 has TWO flip flops! You must have ALL unused inputs of a 4000 series CMOS IC tied to either Vdd or Vss, or your IC may oscillate unpredictably and overheat.
    You can connect them directly (hard-wired), or through a resistor - but they must not be allowed to "float".
