Did you take a look at Ronald Dekker's page?Alright, i still have one major issue tho, how should i reduce the current to the nixies?
My converter says 180V @ 12mA out, nixies need 170 to light, they will run at that or even down to 150ish once lit without problems, and they need 2.5mA.
how can i do this?
You won't know until you measure it, now will you?Actually, when i was using it the nixies seemed very dim... I might need less
The term "rheostat" refers to a variable resistor with just two leads. A potentiometer aka "pot" has three leads, and can also be used as a rheostat by just using the wiper and one of the end connections. There are wire-wound rheostats, but they are expensive and generally pretty low in resistance.and would a rheostat be more reliable, assuming the resistor is still in the line?
I see. Well, might be possible to rig up a circuit with an LDR (light-dependent resistor) to change the current depending on the ambient light.i need something along those lines to control the brightness of the nixies, while they look dim in light they can be pretty bright in the dark.
That was just from the aspect of safety; if you were going to be adjusting it when the HV was on, it would be better to have the pot on the cathode side near ground.also, why have the pot on the cathode side and not the anode side?
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
