4017 delay?
Discussion in 'General Electronics Chat' started by MikeA, Jun 29, 2013.
  1. MikeA
    Jan 20, 2013
    125
    17
    I'm trying to insert a delay after the typical 4017 cycle. Say I have a 555 timing the 4017 at 10hz, so each output will have a period of 100ms. I'd like for the 4017 to go through one of its cycles, then pause for say 1 second. Then repeat the cycle with 100ms period, pause for 1 second again, and on and on. Any ideas how to accomplish that?:confused:
  2. GopherT
    Nov 23, 2012
    6,319
    4,043
    I am not exactly sure what you mean. Could you please make a graph of what you want. X-axis is time. Make three off-set signals moving across the graph (555 signal, 0.1 sec, 1 sec)
  3. Ron H
    Apr 14, 2005
    7,050
    657
    I can show you how to do it, as long as you can tolerate the 10th stage being on during the pause.The 4017 does not contain logic that allows all stages to be off.
  4. MikeA
    Jan 20, 2013
    125
    17
    Ron H, sure, that would be acceptable. So if it's 10hz, it will be...
    100ms, 100ms, 100ms, 100ms, 100ms, 100ms, 100ms, 100ms, 100ms, 1000ms (on)?
  5. MikeA
    Jan 20, 2013
    125
    17
    Something like this....
    on (100ms), off(100ms), on(100ms), on (100ms), off(100ms), on(100ms), on (100ms), off(100ms), on(100ms), off(100ms), pause(1000ms)...and repeat...
  6. Ron H
    Apr 14, 2005
    7,050
    657
    That doesn't make sense to me.
    A timing diagram, showing all 10 outputs, would be nice.
  7. GopherT
    Nov 23, 2012
    6,319
    4,043
    I think I understand (assuming you meant on/off every 0.1 sec). Then off for one second.
    I don't think I have ever submitted a hand drawn schematic before.
  8. MikeA
    Jan 20, 2013
    125
    17
    Like this. X-axis is milliseconds, in 100ms increments. Y-axis is 1 = on, 0 = off.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    A 4017 has 10 outputs. Is that supposed to represent all of them, or only one?
  10. GopherT
    Nov 23, 2012
    6,319
    4,043
    MikeA,
    Ok, do what I suggested in my drawing but on 4017A, connect pins 2, 4, 5, 6, 8 to ground with a 10k resistor. You will get your pattern from pionts 1, 3, 7 and 9 (connected as shown in my previous hand-drawn schematic).
    The OUTPUT you need comes from the AND gate in my drawing.
    RON,
    It looks like he only wants one output but he has a CD4017 to work with.
  11. absf
    Dec 29, 2010
    1,493
    374
    The way I did it is similar to GopherT . But the 1S delay is slightly shorter and the first pulse is about 70% of 100mS. I used a 4011 Quad NAND, but 3 of them are used as inverters.
    Here is the schematic and captured scope wave form.
    Allen
    [edit] U2 "MR" pin should be grounded.
  12. LDC3
    Apr 27, 2013
    920
    160
    What about pin 0?
  13. LDC3
    Apr 27, 2013
    920
    160
    absf,
    There is a problem with your circuit. The CO line is low when any of the last five lines is high, not when the last line goes high (or after) as the circuit expects. See page 7 here.
  14. GopherT
    Nov 23, 2012
    6,319
    4,043
    Pin 0 should connect to the input of CD4017(B) as shown in the schematic.
  15. absf
    Dec 29, 2010
    1,493
    374
    U3 is not enabled until U2 Q9 is high. Even though the clock pulses kept coming in. Q0 of U3 would be stuck in high until U2 has finished doing its job. I only need the first o/p to be high to work.
    I have simulated the circuit and it works. Take a look at the wave form from the O-scope?
    Allen
  16. MikeA
    Jan 20, 2013
    125
    17
    Thanks guys. Seems the 4017 is more trouble than it's worth, especially since I want the outputs to be independent. I might as well get a small PIC to blink some LEDs. It will offer much better timing control.
  17. LDC3
    Apr 27, 2013
    920
    160
    You don't have Q0 on U3 connected to anything. You have CO connected to the NAND gate.
  18. absf
    Dec 29, 2010
    1,493
    374
    On a closer look at my schematics, I found bigger mistakes and wonders how it simulates successfully. Besides the CO (carry out) is wrongly used, I cannot understand how the clock pulses can get through U4C when Q9 of U2 was high all the time and it mysteriously goes low on the 18th pulse.
    I need to breadboard the circuit when I have more time to confirm if my simulator is having some library component error on the 4017. But anyway the OP has abandoned the use of discrete logic chip and opt to use a small mcu to implement his circuit,, so I see there's no big hurry to make my circuit to work.
    I used excel to enter the event table for the 2 4017 inputs and output just for someone who is interested to tackle the problem.
    cheers
    Allen
  19. LDC3
    Apr 27, 2013
    920
    160
    Allen,
    There is a mistake in your table for U2, the Enable should be high for clock count 9 (or is it 10) through 16 to hold the counter from advancing.
