Well, using MOSFETs with diode-ORing won't work terribly well either - you'd need pull-down resistors on each gate to make sure that they are turned off when they are supposed to be off.
Transistors and diode ORing just won't work for this; ran into this very problem with a project I was helping OxboRene with about a year ago. At that time, I determined that 3.9k was the minimum size for the output resistors and still maintain a valid logic '1' level with the cascaded OR gates. I used 5.1k for these schematics to have an extra margin of safety.
But like I speculated above, I think the EL inverter box probably requires a couple of hundred mA (or more) during start-up. Some vendors say that you can't use rechargeable batteries for their EL units, leading me to reach the above conclusion.
I'd mentioned the 2N7000 a couple posts ago, now I'm thinking those will be inadequate. Not sure that even the IRLD024s will work. IRLU024's would; these are 3-legged critters in a TO-251 case (IPak), sort of like a small TO220 package.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=IRLU024NPBF-ND
They are not dissimilar to IRLR7807's that I sent to you, Bill - except these have long terminals instead of pre-formed leads.
