4013 Set/Reset Help
Discussion in 'The Projects Forum' started by dluiz777, Mar 8, 2013.
  1. dluiz777
    Mar 8, 2013
    I would like to use 4013's as a 1 of X type switching system.
    IOW, I have a circuit using (4) 4013s and when I press one of the momentary switches (connected to the CLK input), I'd like to reset the current FF and activate only the selected FF.
    Basically, reset the active FF and activate the FF of the pressed switch.
    Do I need to delay bringing the set input (pin 6) low prior to bringing the CLK input high? I know bringing all the set inputs low, resets all the FF.
    Any help would be greatly appreciated!
    Thank you .. David
  2. dluiz777
    Mar 8, 2013
    Example circuit
  3. sheldons
    Oct 26, 2011
    616
    101
    you either need a hi going signal on the set or reset lines for reset of the 4013-heres a data sheet for you....
