4013 problem
Discussion in 'General Electronics Chat' started by Robin Mitchell, Sep 25, 2010.
  1. Robin Mitchell
    Oct 25, 2009
    738
    207
    I have a 4013 CMOS
    I connect every pin to ground except the outputs and the VCC
    I test the outputs, why is the complimentary output 0 and the normal input 1, reset , set, data and clock are low!
    ARRGGGG!!!
    Also, can you damage CMOS chips by leaving pins floating?
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    Set it up in a functioning circuit then it will work.
    Don't leave CMOS pins floating.
    Why don't you read up on CMOS logic chips before you go putting power to them? What's the point?
  3. R!f@@
    Apr 2, 2009
    8,791
    771
    Never leave CMOS unused inputs floating and always leave an unused output
  4. Robin Mitchell
    Oct 25, 2009
    738
    207
    I use CMOS often its just that for some reason my 4013's first output is one when it should be 0. Thats all
    I know not to leave pins floating, i was just curious thats all!
  5. R!f@@
    Apr 2, 2009
    8,791
    771
    If you are sure then u have faulty device
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    If you want good advice, post a schematic.
    That way we can see if there is anything wrong.
    You can also read the CMOSIntro PDF (attached).
    It gives you information on input / output levels and loads.
    Bertus
  7. Ron H
    Apr 14, 2005
    7,050
    657
    It sounds normal to me. With all inputs grounded, the output can come up in either state when power is turned on, and will not change until the clock input changes from low to high (with a risetime less than the tRCL spec), or you assert either SET or RESET.
  8. Robin Mitchell
    Oct 25, 2009
    738
    207
    ARE YOU SERIOUS!!!!
    This is just perfect! Now i have to make sure that when power is connected, all the 4013 resets are set high! :mad:
    What a silly chup, but THANK GOD its not broken :)
  9. Jony130
    Feb 17, 2009
    3,991
    1,116
    All you have to do is to put simply RC network typical 100K and 100nF.
    See C2 and R5
    Almost all chip need proper reset in start-up.
