400w TDA2030A OR 200WTDA2030
Discussion in 'The Projects Forum' started by mostafa_gordy, Nov 18, 2012.
Thread Status:
Not open for further replies.
  1. mostafa_gordy
    Feb 28, 2012
    57
  2. mostafa_gordy
    Feb 28, 2012
    57
    hello ... :D
    I am Not totaly beginner in electronic but partly beginner in Audio Amplifier .
    my orginal specialty in the Chemistry ...
    please guide me to build this Amplifier .
    I would to use two TIP36b +two 2N3055
    and two of TDA2030A (18W +-44V) in project
    1-Whats schematic is best and why ??
    2- possible connect this amplifier to PC OR home cinema .(in german article :input impedance = 22k Ohm) :confused::confused::confused:
    3-whats best function this amplifier :for subwoofer or coaxial or woofer speaker and whats output impedance (2*TIP36b+2*2N3055
    4- WHATS BOX for this circuit (Empty ATX PSU IS GOOD) :eek:
    5- heatsink need for transistor and TWO IC ?:confused:
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    The first thing I notice is this amplifier has no provision for soft start at turn on and turn off which means the speakers are going to get hit with the big ugly thump.
    I am not certain about the loop stability: adding external transistors significantly increases gain, but the R-C compensation is basic as provided just for a single 2030. It may work, maybe not. I recall building a similar bridge amp using the TDA2003 and I had to tweak the compensation.
    To be completely honest: I worked as a designer at fairchild Semiconductor and did the design for the TDA2030 back in about 1979. It is intended for "medium" fidelity applications (even 30+ years ago), it's not a device I would use to build a home entertainment system around.
    Stereo amplifiers are so cheap these days it really makes no sense to build one. Just my opinion.
    from ebay:
  4. mostafa_gordy
    Feb 28, 2012
    57
    diy work is didactic . pleasure. sloth is not good select.
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Have you found out how much your transformer for this project will cost. I am quite sceptical to the numbers here. Also the 2N3055 is not very suited for audio applications. Both designs appears to be somewhat old. You can get power audio ICs that include a lot like muting and thermal protection. As an example take a look at the TDA7294V
  6. mostafa_gordy
    Feb 28, 2012
    57
    I am change project :because power transformer 500va not cheap & ....
    now my project is : Single Supply High Power Amplifier TDA2030A + npn/pnp :
    http://elcircuits.com/single-supply-tda2030-and-tip41-tip42-2sc10612sa761-or-bd908-bd907
    severl question :
    1- whats way to increase power of this circuit ?
    2- TIP36B & 2N3055 IS woking in this circuit or not? how many change circuit with use these Transistors
    3- best circuit of two : Single Supply TDA2030A BD907 BD908 or TDA2030A Bridge with split power supply 34w Vs-+16
    ( DC VOLTAGE of my Transformer is 29 v )
    4- what is way to increase current of transistor output without voltage increaseing ( darlington for every npn and pnp or parallel transistor)
    please guide me to
    regad .
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    This circuit is in the datasheet for the TDA2030A so look at its specs:
    35W at fairly low distortion when the supply is 39VDC.
    Your old transistors are almost the same as the old transistors used in the datasheet so the results will be the same.
    A single or a dual polarity supply will be the same.
    One TDA2030A driving two [power transistors has an output of 35w into 4 ohms when the supply totals 39.
    The bridged two TDA2030A amplifiers produce 34W into 8 ohms when the supply totals 32V. The ICs get VERY hot.
    Ohm's Law says that you cannot increase the current without increasing the voltage. A bridged amplifier almost doubles the voltage which almost doubles the current. So the power is almost 2 x 2= 4 times (it is 3.5 times). When the load is 4 ohms instead of 8 ohms then the current is almost doubled so the power is also almost doubled.
    Simply calculate the maximum peak-to-peak output voltage needed for the impedance of your speaker. Then calculate the needed peak current.
  8. bountyhunter
    Sep 7, 2009
    2,498
    507
    I was being polite. There are a lot of things a decent amp needs which I don't think you would be able to design. safe turn ON/OFF is one, also they have current limiting in the output device to keep them from blowing up the amplifier or frying speakers.
    I would STRONGLY advise following this excellent advice:
    There are many fully integrated power amp devices that give excellent sound.
    The smart engineer knows when it makes no sense to reinvent the wheel.
    Good luck.
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    Many half-decent inexpensive audio amplifier circuits or ICs shut down if the output is shorted.
    The circuit you are looking at burns out instead.
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    Good point. Adding external power devices means they have no current limiting or thermal protection which the circuitry inside the IC does.
  11. mostafa_gordy
    Feb 28, 2012
    57
  12. Audioguru
    Dec 20, 2007
    9,411
    896
  13. mostafa_gordy
    Feb 28, 2012
    57
    possible to replace BDX54C & BDX53C(hfe=750) WITH TIP36B & 2N3055 (hfe=20)
    or not possile?
    please help me to builde this project correct!!
  14. elektronik
    Nov 22, 2012
    Do not attempt to do this.
    or 36 volts to do
  15. t06afre
    May 11, 2009
    5,939
    1,222
    As said before. I would not have used those transistors. Can you not get any other? And is it any reason why you have to use the TDA2030.
  16. mostafa_gordy
    Feb 28, 2012
    57
    thank you for comment
    my answer is :
    possible to replace pairs Drlingtons (BDX54C &BDX53C) WITH tip36 and 2n3055 with very low Hfe prameter and ......
    nice day ......
  17. t06afre
    May 11, 2009
    5,939
    1,222
    No need to be impudent, is it! Why not go ahead and build the last power amplifier you posted. And then do some experimenting. That is all I can say.
  18. Audioguru
    Dec 20, 2007
    9,411
    896
    The latest circuit is almost the same as figure 12 in the datasheet for the TDA2030A.
    It does not use and does not need darlington output transistors because its output power is not high.
    It is an ordinary stereo amplifier that is not bridged. Since its supply voltage is only 36V then its output power per channel is only 28W at clipping into 4 ohm speakers.
    If the two amplifiers are properly bridged then the output power will be about 100W at clipping into 4 ohms.
  19. t06afre
    May 11, 2009
    5,939
    1,222
    I also think a bridged setup, using only TDA2030. Will be a much better setup. Than anything else you have shown so far.
  20. Audioguru
    Dec 20, 2007
    9,411
    896
    The bridged amplifier in the datasheet that uses two TDA2030A ICs without additional output transistors has an output of only 34W into 8 ohms with a 32V supply. The current and heating might be too high if the speaker is 4 ohms and/or if the supply voltage is higher.
    A much better amplifier IC is the LM3886. It is truly high fidelity, is inexpensive and has an output of 68W into 4 ohms with a 56V supply or 50W into 8 ohms with a 70V supply.
    Two LM3886 amplifier ICs can be bridged to give an output of 110W into 4 ohms with a 40V supply if the heatsink is really good. With two ICs bridged, the power into 8 ohms is 120W with a 56V supply.
    LM3886 amplifier ICs are shown in National Semi's (TI now) application note AN1192 paralleled and bridged to provide 150W and 200W into 4 ohms.
Thread Status:
