I have never used a microcontroller before. I picked up the PIC18 to use for this project which looks able to handle the job. For each window there needs to be an ON conditional output to light a 2-3V LED for each window independently when the VDC signal is within a defined range. From what I have been hearing, this should be fairly straightforward. Does anyone have insight on how to code this or can point to helpful tutorials?
