4 to 1 multiplexor
Discussion in 'Homework Help' started by rj2222, Sep 16, 2005.
  1. rj2222
    Sep 16, 2005
    help please!!! I have a project to make this schematic but i'm a little stuck......any advice/help would be GREAT! I'm using Xilinx or tkgate to do this....
    1a
    Design a 4-to-1 multiplexor with a 2-bit selector.
    1b
    Using the design from 1.1a, build a 4-to-1 multiplexor that uses 8-bit buses instead of the single bits in 1.1a.
    thanks!!!
  2. GnatWest
    Apr 24, 2004
    Assuming you are using a programming language like vhdl, this can be as easy as a case selection using the following type of architecture.
    inputs d0-d3, s0-s1
    when s0,s1 = 00 then output = d0
    when s0,s1 = 01 then output = d1
    - Good Luck
