4 terminal inductor
Discussion in 'Electronics Resources' started by blackhole, Dec 20, 2010.
  1. blackhole
    Nov 29, 2010
    8
    how i can connect an inductor which has 4 terminals???
    and what is the the difference between it and two terminal inductor??
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    It may be a transformer.
    John
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    It could be a Current-Compensated Ring Core Double Choke.
    These are used at the input of a smps for line filtering.
    Attached is a datasheet from epcos with closed housings, bit the inner is the same.
    Bertus
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    What are you attempting to use it for? Are there any markings on yours that would indicate value?
    More than two leads usually indicates a transformer or a multi-tap inductor for either different values or use as an autotransformer.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Perhaps what you have is a common-mode filter.
    hgmjr
  6. blackhole
    Nov 29, 2010
    8
    thanks for all i understand the story of this inductor :)
