4 string from adapter, 2 of 3 bulbs work
Discussion in 'General Electronics Chat' started by slambeau, Jan 16, 2012.
  1. slambeau
    Jan 16, 2012
    Regarding a 16 function 150 mini light parellel string with 4 wires from adapter; there are three colored bulbs one (blue) does not light. The functions work well and I changed the 2 fuses in the plug (out of desperation as I knew both fuses had to be working for any lights to work). I am getting ready to attempt to open the adapter (not easy to do as it has a tiny triangle to fit the head of the screw into); any ideas? Set is new used this Xmas season. Thanks to any who has any ideas.
  2. mcgyvr
    Oct 15, 2009
    4,783
    973
    and you've plugged the "not working" bulbs into a different area of the string and they light? Any cuts/nicks/breaks in the wire. (should be easy to diagnose with a multimeter)
