4 quadrant multiplier
Discussion in 'Homework Help' started by romy, Nov 30, 2008.
  1. romy
    Nov 30, 2008
    12
    hi
    any 1 could help me to design a 4 quadrant multiplier, i have no idea of analog circuit so if possible can u tell me where is best way to start the work.
    with regards
    romy
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. romy
    Nov 30, 2008
    12
    i guess data sheet will not work for me, its a course work to design a 4 quadrant multiplier using bjt so could u sent me a link about it
    many thanks
    romy
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Well, if the schematic in the data sheet isn't enough to give you a start...
    I have moved this ti the Homework section. Post up what you have got accomplished and we'll lend a hand.
  5. hgmjr
    Jan 28, 2005
    9,030
    214
  6. steveb
    Jul 3, 2008
    2,433
    469
    I hope you are exaggerating when you say you have no idea of analog circuits. A four quadrant multiplier is not the place to start learning. In my opinion, if your statement is accurate, the best way to start is to learn about simple OPAMP circuits like the inverting amplifier, and then study the principles of a bipolar junction transistor and pay attention to the temperature dependence of that device. Then, you will be in better position to tackle the multiplier circuits.
  7. leftyretro
    Nov 25, 2008
    394
  8. steveb
    Jul 3, 2008
    2,433
    469
    Just to provide more information, here are two more references.
  9. romy
    Nov 30, 2008
    12
    many thanks
  10. pedot
    Dec 1, 2008
    hi..
    I also need to design 4 quadrant multiplier..using bjt
    by referring to suggested references..now i know how to start..
    Many thanks.
