4 prong high output LEDS
mrmeval
Joined Jun 30, 2006
833
The datasheet shows the cathode, I would assume the other pins are the anode. For that particular device I'd recommend a current regulator.
Just an example, it's easy to get and can be wired as a current regulator. There are several variants in this datasheet.
http://www.hep.upenn.edu/SNO/daq/parts/lm317.pdf
I think that unreasonably lousy datasheet is saying you need 40 milliamps but start with 20.
