4 pin car relays
Discussion in 'General Electronics Chat' started by Cossiedave, Mar 2, 2007.
  1. Cossiedave
    Mar 2, 2007
    Hi HELP can anyone tell me how to wire a 4 pin relay on my car its needed in a cooling fan circuit :confused: ;)
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Can you provide any information on the relay part number and/or perhaps a jpeg of the relay itself?
    hgmjr
  3. Cossiedave
    Mar 2, 2007
    hi all that I know is that its a ford relay with terminal # on it 30 85 86 87 I need to know which terminals are from the switch and which are load ?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you have a meter, look for the pair of terminals that show a resistance. The other pair will be the load terminals, and should check open. Resistance through the coil may be in the range of 100 - 500 ohms.
    If you have not got a meter, you can use clip leads or even wires to make a connection between ground (any part of the car or the battery terminal) and the battery positive terminal. The pair of pins that produce a click from the relay are for the coil.
  5. Cossiedave
    Mar 2, 2007
    Thanks very much a great help
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    You may want to also pose this question on one of the many forums dedicated to automotive repair such as the one linked to below.
    Automotive Forum
    hgmjr
