4 phone lines with one cat6 cable
Discussion in 'General Electronics Chat' started by electronewb, Oct 29, 2014.
  1. electronewb
    Apr 24, 2012
    260
    Hi guys Is it possible to have 4 phone lines using 1 cat6 cable? Basically I want to use 4 Rj11 plugs on one side of the cable and 4Rj11 box with jacks at the other end of the cable (so I can extend from a box to an actual phone) I believe only 2 wires are needed for a phone line and the contacts on the Rj11 are the 2 middle ones. Is that correct?
  2. Sensacell
    Jun 19, 2012
    1,184
    277
    Yep- but the jacks /plugs need to be 8 circuit RJ-45, not RJ-11
    4 pairs = 8 wires = 4 phone lines
    Just don't get 'em mixed up
  3. electronewb
    Apr 24, 2012
    260
    Thanks for the reply. What do you mean by 8 circuit Rj45? You mean I need to use Rj45 connectors and jacks and not rj11? What would be the difference? Also this is right that only the 2 middle tabs are used for phone lines?
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    RJ11 is right.
    Yes.
    So what you trying to do is a 4 phone lines extension connector?
  5. Sensacell
    Jun 19, 2012
    1,184
    277
    yes RJ-45 is an 8 wire jack, but the phones are 6 wire.
    Use RJ-45 for the cat-6 then break out the wires to the RJ-11
  6. ScottWang
    Aug 23, 2012
    4,933
    777
    Phone are 4 wires used in single phone line.
    If the TS used telephone switchboard then 4 wires is not enough.
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,705
    1,300
    An RJ-11 connector has six contact locations, but it takes only two (the center two) for a standard POTS phone. Very low-cost appliances such as answering machines used to come with an RJ-11-to-RJ-11 cable with only the center two contacts installed.
    Phone circuits are DC. A true analog phone won't care about polarity, but some electronic phones will not work with the wires reversed.
    ak
  8. electronewb
    Apr 24, 2012
    260
    Here's what I'm trying to do
  9. Manfred Mans Earth Band
    Oct 5, 2014
    17
  10. djsfantasi
    Apr 11, 2010
    2,911
    881
    It used to be, that an analog phone won't break dial tone if the wires were reversed. Made dialing impossible!
  11. electronewb
    Apr 24, 2012
    260
    But is what's on the PDF that I've attached work?
  12. djsfantasi
    Apr 11, 2010
    2,911
    881
    In your PDF, are all the wires contained in the cat 6 cable?
    Will the RJ11 jacks be connected by uncovered twisted pair?
    Would you consider a second box where the Ethernet cable was broken out to individual 4 conductor cables for the phones?
    Also? Why cat 6? Availability? Cat 6 is more stiff or rigid than cat 5/5e. Is that ok? And more expensive. Both have eight conductors.
  13. electronewb
    Apr 24, 2012
    260
    I have tons and tons of cat6
    But would my wiring works?
  14. GopherT
    Nov 23, 2012
    6,326
    4,054
    Answer the rest of disfantasi's questions in post 12, then we can start with some options...
  15. electronewb
    Apr 24, 2012
    260
    I did For some reasons the answers in my post were all over the place
    In your PDF, are all the wires contained in the cat 6 cable? Yes
    Will the RJ11 jacks be connected by uncovered twisted pair? I will put heatshring tubing on each pair
    Would you consider a second box where the Ethernet cable was broken out to individual 4 conductor cables for the phones? That's the plan each box will get a regular phone cable that will be hooked up to a phone
  16. djsfantasi
    Apr 11, 2010
    2,911
    881
    The wiring concept will work. The devil is in the details. The pairs must go to the correct pins in the jack/plug. Where the pairs separate, be sure to include strain relief. And protect the cables/wires where they enter/leave the boxes. And I'd make sure the polarities are correct, although others have indicated it may not be necessary.
  17. electronewb
    Apr 24, 2012
    260
    Great thanks!!!
