4 digit up/down counter
Discussion in 'Homework Help' started by Mhine28, Sep 2, 2014.
  1. Mhine28
    Sep 2, 2014
    10
    hi to all. could someone help me make an up/down counter.
    i'm having problems in making my circuit work.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    You left out the connection between pins 4 and 6....;)
    If fixing that doesn't help, perhaps more information is in order...
    bance likes this.
  3. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi,
    These are 3 decade Up/Down counters, just add another stage for 4 decades.
    E
  4. Mhine28
    Sep 2, 2014
    10
    i'm using 7447 instead of 74247..
    is that possible?
    and can that circuit be set to start to a certain number?
    thanks for the reply.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    The 7447 and 74247 are comparable.
    The 247 is most likely a newer version.
    Take a look at the internal schematic of both.
    Bertus
  6. ericgibbs
    Jan 29, 2010
    2,605
    396
    The pin outs for the 7447A are the same as the 74LS247, so they should be OK.
    E
  7. Mhine28
    Sep 2, 2014
    10
    ok thanks alot..
    what about 74192, im using 74193 are they comparable?
  8. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi,
    No,
    One is a binary counter [193]and one is decade counter.[192]
  9. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Bernard and Mhine28 like this.
  10. Mhine28
    Sep 2, 2014
    10
    can i use that circuit for multiflexing?
    i am suppose to change the number of each digit using an up/down counter.
    and if possible can you tell me how?
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    So, this is an assignment for school. Why didn't you start off saying that?
    Why don't you post YOUR circuit that you seem to be having trouble with?
    We're not here to do your homework for you, as you wouldn't learn how to do it yourself. If you are really stuck and can't figure something out, we can help you past that point.
  12. Mhine28
    Sep 2, 2014
    10
    here is the schematic diagram that I found in the internet..
    i couldn't make it work..
  13. MrChips
    Oct 2, 2009
    12,652
    3,461
    Don't try to fool us. You really didn't build this circuit.
  14. tshuck
    Oct 18, 2012
    3,531
    675
    Is there any work you have done yourself on your homework?
    Please make a legitimate effort on solving your homework problem first, before consulting the internet - including asking us.
  15. Mussawar
    Member
    Oct 17, 2011
    68
    I mostly build decimal counters with 40110 along with a good debouncer.
  16. Mhine28
    Sep 2, 2014
    10
    no i didnt...
    i said "I found" that means i searched that...
    i was hoping that if someone can tell me why even if i connect the circuit it wont work...
  17. tshuck
    Oct 18, 2012
    3,531
    675
    One of two reasons it won't work:
    1. You hooked it up wing
    2. The schematic is wrong
    There are many reasons that could have gone wrong in either process. For is to tell you what you did wrong would require knowing what you did - something you haven't been very forthcoming with....
  18. MrChips
    Oct 2, 2009
    12,652
    3,461
    I said "build this circuit", not "design this circuit".
    We know you didn't design the circuit. We also know you didn't build the circuit.
    So how do you know whether or not the circuit works?
  19. MrCarlos
    Jan 2, 2010
    400
    134
    Hello Mhine28
    The circuit contained in the image that you enclose, is not quite right.
    Look at the notes I added in it. (In black and red line)
    Many of the circuits that we found on the internet do not work.
    This is another case.
    It is easier and faster if you look around here on the forums trying to find a Up-Down circuit that meets your requirements.
    You also need to study the data sheets from the ICs you intend to use
    You can get them at this link: http://www.alldatasheet.com/
  20. Mhine28
    Sep 2, 2014
    10
    thanks for the info.
    and thanks for helping me out coz im just a newbie..
