4 conductor wire gauge
Discussion in 'General Electronics Chat' started by stoopkid, Nov 26, 2011.
  1. stoopkid
    Mar 3, 2011
    136
    I'm looking for some 4 conductor wire to connect RGB LEDs. 18 gauge speaker wire comes up a lot but I was wondering if that means the whole thing is 18 gauge or if each conductor is 18.
    Thanks!
  2. K7GUH
    Member
    Jan 28, 2011
    191
    23
    I think it means each conductor is 18 ga., but I've been mistaken before.
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    22ga twisted pair (2 pair) was a very common wire used for telephone.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Cat5 Cable, 8 strands of 4 twisted pairs, each wire is 24 gauge and can handle 1 amp without a sweat.
    Cat3 telephone cable is similar, 22 or 24 gauge wire. Unless it is a long run for a high current LED, either should work fine, and the wire is cheap when purchased in bulk or off bulk reels.
  5. tracecom
    Apr 16, 2010
    3,884
    1,396
    If you want cheap, try to find an old parallel printer cable at the local thrift store or computer repair shop. The wires are usually 28 gauge stranded and are fine for most low voltage, low current projects (like LED's.) Remove the outer sheath and you will find a great assortment of colored wires. Pick out some colors you like and make your own harness. You can use some tiny pieces of heat shrink tubing (or tape or bread ties) to hold the wires together.
