4 Channel LED colour organ not working
Discussion in 'The Projects Forum' started by Max12345, Oct 6, 2013.
  1. Max12345
    Aug 27, 2013
    63
    Greetings
    I've built a 4 channel LED colour organ using a circuit by Ledartist.
    All the LEDs come on and stay on without audio input.
    Assuming that there are no faults on my veroboard, what could possibly be the cause/s? I've checked and rechecked the circuit and the layout and cleaned the flux.
    I just need some pointers on where to look.
    http://www.instructables.com/id/Color-Organ-Triple-Deluxe-II/
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    What is the supply voltage?
    What are the voltages on the bases of Q3, both Q5s, Q7?
  3. tubeguy
    Nov 3, 2012
    1,157
    197
    +1 If you were using a 12VDC supply you should see about 0.43VDC on those transistor bases; the LED's would be off with no audio signal.
    Wild guess > are the 270K resistors the correct value (270,000 ohms)?
  4. Max12345
    Aug 27, 2013
    63
    Hi guys
    Alec_t, the supply is 12V.
    Tubeguy, the 270K resistors are correct as per Ledartist's circuit.
    I have uploaded ALL the base voltages on the new "Original and changes 2" schematic for your perusal.
    Thanks so much
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Those voltages are seriously not what they should be. Double-check that you have the pin-outs of the transistors correct.
  6. MrChips
    Oct 2, 2009
    12,655
    3,461
    I agree. There is something dramatically wrong with your setup.
    Post clear well focused photos of both sides of your circuit board.
  7. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Check also that the bottom ends of R9,R14,R19 are properly grounded.
  8. tracecom
    Apr 16, 2010
    3,880
    1,396
    When my prototypes don't work, my first assumption is that there IS something wrong with my wiring. Using a marked up schematic increases the likeliehood that something is wired wrong. The easiest thing to double check is the pin out on the transistors; viewed from the flat front, the leads are l to r, c, b, e.
    Did you breadboard the circuit before you put it on veroboard?
  9. MrChips
    Oct 2, 2009
    12,655
    3,461
    Not for 2N2222A it ain't.
  10. tracecom
    Apr 16, 2010
    3,880
    1,396
    Note to self: don't go by memory. :)
    (Original post corrected.)
  11. Max12345
    Aug 27, 2013
    63
    Gents, you've found the problem (sheepish grin).
    I used the P2N2222A pinout configuration for the KSP2222A and they are not the same! My transistors are connected wrong way round.
    The store at which I purchased the transistors has a datasheet of their transistors and when I clicked on the sheet for the KSP222A, the sheet of the P2N2222A came up and I assumed that they were identical. Assumptions...
    http://www.mantech.co.za/Stock.aspx?Query=ksp2222aand
    Tracecom is correct in his layout of the P2N2222A, although I think that the 2N2222A is a can. That is the way I have it on my vero.
    So are they all shot now? Or should I still bother to check them before buying others?
  12. Max12345
    Aug 27, 2013
    63
    I didn't, my breadboard is too small...(another sheepish grin)
  13. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Probably not. Re-connect them right way round and give 'em a try.
  14. MrChips
    Oct 2, 2009
    12,655
    3,461
    Well, Alec_t had said it first. I looked at your photo and figured you had connected it correctly.
    I reversed the pinouts in a simulator and did not arrive at your values. So I assumed that you had another problem somewhere.
  15. Max12345
    Aug 27, 2013
    63
    So he did, MrChips, so he did. Thanks Alec_t.
    I'll whip 'em out and replace them and see...
    Thanks again
  16. tracecom
    Apr 16, 2010
    3,880
    1,396
    Well, I was confused as well. I keep and use the PN2222A, which has a l to r pinout of e, b, c. My mistake was in not realizing that the 2N2222 is a can with a different pinout; I thought they were just two different numbers for the same thing. When I looked at the photo, that confirmed my erroneous belief, all of which is the reason I posted wrong info about the 2N2222 and had to correct it. Thanks to MrChips. :)
    I am sorry for any confusion I caused, but I learned something I won't soon forget.
  17. Max12345
    Aug 27, 2013
    63
    All the transistors worked, except 1, which also worked, but only dimly switched on the LED in my transistor tester, so I replaced that one.
    Circuit works now, thanks.
    However, now I have to work on the filters. A link to a sound card generator given to me by bertus, shows that there is too much overlap between the bands.
    http://www.twopaths.com/Software/index.htm
  18. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Glad you got the main problem sorted out. Let us know how you get on with the filters.
    Max12345 likes this.
