4 bit up counter
vead
Joined Nov 24, 2011
629
You fixed it. Your counter would have counted up to 4 and stayed there indefinitely had it been implemented as you had shown (100 goes to 100).
we knew the next state so now why we need to k map
thanks lot tshuck today you taught me lots about digital electronics
tshuck
Joined Oct 18, 2012
3,534
Technically speaking, we don't. However, you would need a huge amount of gates to do this. The K-maps are to reduce the input-forming logic, or the logic that will generate the next state values for the inputs to the D flip-flops for the next clock edge. If you don't do the K-maps, you would have to decode each current state value to produce the inputs for the next state and select the correct input accordingly.
The K-maps make your life easier.
You are welcome, it's what I'm here for.:)
vead
Joined Nov 24, 2011
629
I understood the function table of Counter IC by datasheets but when we implement counter Ic with flip flop how to understand the table
simple I made up counter with four d Flip flop that count 0 to 7 number now I am having trouble to make datasheet for counter I tried can someone help me to make the table for counter
what is process to make table for up counter using d flip flop
what should we first know step by step to make table
WBahn
Joined Mar 31, 2012
29,976
so how to find out next state
truth table
N C B A next state
0 0 0 0
1 0 0 1
2 0 1 0
3 0 1 1
4 1 0 0
5 1 0 1
6 1 1 0
7 1 1 1
Well, if you are in state 011, what is the next state you want to go to if this is an up counter? Also, if it is a 4-bit up counter, then don't you need 4-bits of state information (at least)?
WBahn
Joined Mar 31, 2012
29,976
What table? Next state table? Transition table?
If you made an up counter that only counts from 0 to 7, why did you need four flip flops?
It is still far from clear that you have firmly established what it is that you want this black box to do.
What, exactly, are the inputs to this black box that you are calling a 4-bit up counter? What, exactly, does each input mean?
What, exactly, are the outputs from this black box. What, exactly, does each output mean?
Unless you can clearly and precisely describe the interface to this black box detailing exactly what it is you want the black box to do, you don't stand a chance in hell of putting something inside that black box that will do what you want.
vead
Joined Nov 24, 2011
629
yes you are correct that's not four bits its 3 bit up counter
table for 3 bit up counter
present state next state
N A B C
0 0 0 0 0 0 1
1 0 0 1 0 1 0
2 0 1 0 0 1 1
3 0 1 1 1 0 0
4 1 0 0 1 0 1
5 1 0 1 1 1 0
6 1 1 0 1 1 1
7 1 1 1 0 0 0
present state I think present state means this
N A B C
0 0 0 0
1 0 0 1
2 0 1 0
3 0 1 1
4 1 0 0
5 1 0 1
6 1 1 0
next state means
N A B C
1 0 0 1
2 0 1 0
3 0 1 1
4 1 0 0
5 1 0 1
6 1 1 0
7 1 1 1
0 0 0 0
that's circuit is very complex for me don't know any idea what i do next
1) how to find out what exactly are the input to counter
2) how to find out what exactly are the output to counter
tshuck
Joined Oct 18, 2012
3,534
Minimum, a clock signal, the rest are up to you. Do you want a reset? Do you want to load values into the counter? Do you want to be able to select an up or down count function?
You need to determine the desired functionality before you can design a counter's logic...
Typically you want a counter to count, so the count as an output would be nice. Other than that, you could have a signal showing that the counter is at its maximum count value, but, again, this depends on what you want.
