4 bit up counter
Discussion in 'General Electronics Chat' started by vead, Jan 17, 2014.
  1. vead
    Nov 24, 2011
    621
    8
    I want to design 4 bit counter using D flip flop that will count 0 to 7number I have used 3 d flip flop to make up counter to count o to 7 number
    truth table
    N C B A clk present state next state
    0 0 0 0
    1 0 0 1
    2 0 1 0
    3 0 1 1
    4 1 0 0
    5 1 0 1
    6 1 1 0
    7 1 1 1
    1) how to determine present state
    2) how clok work I mean when does clock raise or fall
    help me to complete table
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Shouldn't you figure out how to make a D flip-flop first? Unless this is to be implemented in behavioral modelling...
    Anyway, you seem confused, assuming C, B, and A are your flip flop outputs, why not use these as your present state? Doing this, you can make the next stage equal to the present state + 1.
  3. vead
    Nov 24, 2011
    621
    8
    A, B, c are the inputs
    I know the basic table of D flip flop with positive edge
    D flip flop table
    d clk q q_bar
    0 ↑ 0 1
    1 ↑ 1 0
    when clock is raising with positive edge output will same as input d otherwise no change
    but in counter there is three d flip flop so how to determine the output?
  4. tshuck
    Oct 18, 2012
    3,531
    675
    What purpose do they serve?
    See this thread I made regarding synchronous counters.
    So why do you need 4 bits to count to 7 (111)?:confused:
  5. ScottWang
    Aug 23, 2012
    4,924
    777
    The first output of D-FF is b0, and it will changing the status while the clock on the rising edge.
    The second output of D-FF is b1, and it will changing the status while the b0 on the rising edge.
    The third output of D-FF is b2, and it will changing the status while the b1 on the rising edge.
  6. vead
    Nov 24, 2011
    621
    8
    ok I have read your post
    now i understood that A,B,C are the output of d flip flops these are the current state your post related to JK flip flop but how canI determine the next state for D flip flop Should I used to K map
  7. tshuck
    Oct 18, 2012
    3,531
    675
    You can have inputs, as in the case with a load function, but considering your grasp of the concept, it's best to say there aren't any.
    Yes, the same idea is applied to D flip flops, but you only need one K-map per flip flop. Another thread I made uses both, but in designing modulus counters. The idea is the same though.
  8. vead
    Nov 24, 2011
    621
    8
    It means that if i want to find out the value of next state i need to k map
    can we use k map for any counter to find out next state
  9. tshuck
    Oct 18, 2012
    3,531
    675
    No, the K-map just gives the implementation. You define the next state. The K-map only works when you know what it is doing...
    The next state is just the next count ( e.g. 1 goes to 2, 2 goes to 3, etc.)
  10. vead
    Nov 24, 2011
    621
    8
    so how to find out next state
    truth table
    N C B A next state
    0 0 0 0
    1 0 0 1
    2 0 1 0
    3 0 1 1
    4 1 0 0
    5 1 0 1
    6 1 1 0
    7 1 1 1
  11. tshuck
    Oct 18, 2012
    3,531
    675
    Count.
    truth table
    N C B A(current state) next state
    0 0 0 0 001
    1 0 0 1
    2 0 1 0
    3 0 1 1
    4 1 0 0
    5 1 0 1
    6 1 1 0
    7 1 1 1
    Note that CBA is backwards from most implementations, usually written ABC...
  12. vead
    Nov 24, 2011
    621
    8
    truth table
    0 0 0 0 001
    1 0 0 1 010
    2 0 1 0 011
    3 0 1 1 100
    4 1 0 0 100
    5 1 0 1 110
    6 1 1 0 111
    7 1 1 1 000
    is it correct
  13. tshuck
    Oct 18, 2012
    3,531
    675
    Say what?;)
    Maybe you should reformat the table - either put it in the table that I did, or space it and put it between some code tags [code ][/code]
    Nevermind, you did that while I typed...
  14. tshuck
    Oct 18, 2012
    3,531
    675
    As is, it will only ever count to 4. A single bit can mess it up...
  15. vead
    Nov 24, 2011
    621
    8
    now
    truth table
    0 0 0 0 001
    1 0 0 1 010
    2 0 1 0 011
    3 0 1 1 100
    4 1 0 0 101
    5 1 0 1 110
    6 1 1 0 111
    7 1 1 1 000
  16. vead
    Nov 24, 2011
    621
    8
    what does it mean?
  17. djsfantasi
    Apr 11, 2010
    2,899
    870
    You corrected your table. Why? I suspect that you saw an error and corrected it. What was the effect of the error before you corrected it?
  18. vead
    Nov 24, 2011
    621
    8
    i did put the wrong value the the sequence of counter may be change
  19. tshuck
    Oct 18, 2012
    3,531
    675
    This looks good to me, just be aware of the input variable sequence (CBA as opposed to ABC) and you should be able to implement the K-maps...
  20. tshuck
    Oct 18, 2012
    3,531
    675
    You fixed it. Your counter would have counted up to 4 and stayed there indefinitely had it been implemented as you had shown (100 goes to 100).
