4 bit jk counter only odd numbers
Discussion in 'Homework Help' started by OMMad, Nov 14, 2010.
  1. OMMad
    Nov 14, 2010
    assignment: design a counter through all the odd numbers from 0 - 15.
    progress: i think i have everything correct.
    can someone verify for me? i'd appreciate if you could point out any mistakes.
    i've attached what i have so far. thanks in advance for any help.
    choijo and Nupur like this.
  2. Ron H
    Apr 14, 2005
    7,050
    657
    Did you notice that Q1, Q2, and Q3 are a standard binary counter, and Q0 is always =1?
    It seems to me that you only need 3 FFs.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Or, if you have the option, use a standard counter IC. Take the 3 MSBs and use a HIGH pin to generate the LSB.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    I was hoping he would figure that out from my post.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    To be honest, I didn't think of an IC counter when I read your post, but of a discrete Flip Flop counter.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, I didn't read your post carefully enough. I was in fact thinking he could design a 3 bit counter from "scratch", scratch being JKs and maybe some gates. I didn't consider that he could use an IC binary counter, and, seeing that it was homework, I'd be willing to bet that I'm right about that.;)
